You'd either have to ask PJ, or you'd have to buy one and try it out. It's still not the most optimal solution, as it puts out a regulated 6.3V, which we drop with a couple of low value resistors to get to 5V.
EricS said:... insert a 0R1 resistor in series that will bleed off 0v19 and shift the heater range down to 4.97v to 5.19v?
Yeah, you would be pulling the winding down a little bit, and the paralleled resistor would pull the voltage down less with lower line voltages and more with higher line voltages.EricS said:Paul: I presume you are recommending the resistor in parallel to place a more "even" load on the AC filament? Does it achieve the same result if I put a smaller resistor in series with each side of the filament?
Hmm, so bring the 5V AC current right up to 2A (with a 50 ohm resistor in parallel with the filament) and call it good?Paul Joppa said:Actually, the primary is designed for a nominal 117 volts 60Hz input and the 5v winding is specified at 2.0 amps RMS.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
