D
Guest
Paul Birkeland said:The manufacturer indicates that about 10V from the amp will be adequate for the LCD-4. You won't get this from a #45 amp or a #45B amp unless you get custom wound output transformers with higher impedance taps to make more power available.
I did some more reading this morning that i think clears this up. IN a FAQ, Audeze explains that the higher Watts recommendation is for transients. That makes sense to me since, according to a couple of online calculators I checked, the 97 dB/mV sensitivity of the LCD4 only requires 63 mW to get to 115 dB - which is pretty loud.
Lundahl makes a headphone output transformer tapped for 4.6K/32, 5.4K/150 and 5.4K/600 ohms: LL2765. Assuming I can get it made for parafeed, do you foresee any problems with trying it? Datasheet attached.
I'd be curious to hear how the SII-45 performs driving the LCD4 with a ton more headroom. The impedance/frequency plot of phones is nearly ruler flat, so I'm thinking the loss of damping with the secondaries wired for 150 ohms might not be a big deal. But I suspect I'd need to pad down the signal, but not sure where in the BeePre -> SII-45 chain.
If it is workable, I could convert the SII-2A3 to run regular 45s with the LL2765, and compare it to the SII-45 rebuild for EML 45B. I think that would be cool.
cheers and many thanks, Derek
