Many thanks PB.
Paul Birkeland said:
The ratio establishes that the output of the amplifier won't vary too much as the load impedance changed (speakers rarely have a flat impedance curve).
This I get (I *think*) - I understand (perhaps simplistically or even erroneously) the good regulation as a consequence of the voltage divider relationship where source resistance/impedance is the first resistor (R1) in series with the voltage source and the load is the second resistor. If R2 is much greater than R1, then small variations in R2 won't cause wild fluctuations in regulation; whereas if R2 is close to R1, the same magnitude of fluctuation will cause a big decrease/increase in voaltge dropping across the load.
IIRC, you get max power when the load impedance is about twice Rp. The loss of power for going to 3xRp is very much worth the trade-off of higher damping and lower distortion.
I really have no clue here. I was just paraphrasing what I remembered reading in Horowitz and Hill, The Art of Electronics 3rd. ed.(my late night bedtime reading, along with Ott's latest edition on dealing with noise and interference - thanks Jamie!
) I just looked it up again - from the end of p. 11: "Show that R-load = R-source maximizes the power in the load for a given source resistance. Note: skip this exercise if you don;t know calculus, and take it on faith that the answer is true." I can;t remember (assuming I ever knew) the calculus necessary to prove this, so I did as instructed and "took it on faith."
If a Kaiju, especially wired for 16 ohms, is giving you a huge performance increase, it wouldn't be unreasonable to infer that this is a possibility.
The Kaiju just sounds better than the SII-45 (which sounds better than the SII-2A3). The K is cleaner and punchier and the treble is amazing. In comparison, the SII-45 sounds a little hazier and less decisive. Is it a huge step up in performance? Dunno. The difference is small, but appreciable. Kind of like a smeared mirror or window: that last fraction of a percent of dirt makes a huge difference; but quantitatively, as a percentage of the
amount of beginning dirt, it is insignificant. At the same time, I imagine there would be no appreciable difference were I using a really cheap DAC, preamp and headphone set - they would add so much "dirt" that the improvement would be buried by the noise floor.
Well I obviously have no basis to assert things are one way or the other and am just relaying what I read. So I looked it up again. IF repeats the less than 0.5V figure twice in the their measurements. Here's the first instance:
"Volts RMS required to reach 90dB SPL: 0.482 Vrms
Impedance @ 1kHz: 206 Ohms
Power Needed for 90d BSPL 1.13 mW
Broadband Isolation in dB (100Hz to 10kHz): -2 dBr"
Second instance (same measurement page):
"The LCD-4 needs 482mVrms to reach 90dBspl at the ear. These headphones will run quite a bit more towards the top of your volume dial than most. But their 200 Ohm impedance means that they're only moderately less efficient than most."
(see http://www.innerfidelity.com/content/technologically-impressive-lcd-4-planar-magnetic-headphone-measurements#S6BkJ5yiLskokcbb.99)
... a Crack could be modified to deliver this kind of power.
That's sounds like a fun experiment. Could you elaborate on the required mods? I have a mostly intact Crack collecting dust that I will happily experiment with.
But in the end: while I can't discount the possibility that I am missing out on what my LCD4s are capable of (and this is a concession I make based purely on logic applied to my acknowledged lack of both empirical experience and knowledge about the science of all this - but my ears say "no way"), I find this almost impossible to even imagine. The sound coming out of them when fed by the BP and K (or by the SII's, to a slightly lesser extent) is superb. Is better sound possible? Probably - I bet the K could be built with even better OPTs that cost thousands or even tens of thousands of dollars more that would make it sound better. Would the Mainline sound better than the BP and K? Maybe one day I'll get to find out. ... But I doubt it. And if so, I'll have the makings for a helluva 2 channel system - I'll just need to buy Jagers, plus move to a place in the country where I won't have the cops at my door every night ;D)
cheers, Derek
