MrPotatoSalad
Got an RCA Cleartop and voltages are good and noise is gone. Volume control is improved as well. Simply beautiful. I'll send my weak tube in for replacement tomorrow.
Thanks a lot PB. ;D
Thanks a lot PB. ;D
Did you replace the transistor AND the tube OR just the tube?MrPotatoSalad said:Got an RCA Cleartop and voltages are good and noise is gone. Volume control is improved as well. Simply beautiful. I'll send my weak tube in for replacement tomorrow.
Thanks a lot PB. ;D
Just the tube for now. The Speedball is out until tomorrow when I get my transistors.Natural Sound said:Did you replace the transistor AND the tube OR just the tube?
I have 49 moreCaucasian Blackplate said:You still have a short somewhere drawing down the power supply. If you run it long enough, you will blow out the 270 Ohm resistors again.
Are you triple sure that the TIP-50 transistors aren't touching the heatsinks in any way?
Oops, I did mean the 270 ohm 5W resistor.Doc B. said:Just to clarify it's the 270 ohm 5W resistor PB is talking about, not a 270K ohm resistor.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
