Paul Joppa said:
Just a note - ground currents (often called "ground loops") do not occur within a component, but rather between components. That's why they are so hard to trace ... :^)
What happens is there is an AC current in the ground side of the interconnect, and that current drops a tiny voltage because the ground wire has some resistance, and that voltage gets added to the signal.
You can start with the Crack no connected to anything, and the volume turned all the way down. If there is hum, it is within the Crack. (You can then turn the volume up, and detect whether there is electromagnetic interference noise - always good to eliminate other possible problems!)
Then connect the DAC to the Crack, with nothing else connected to the DAC. If you get a new hum/noise then the DAC is likely introducing a noise current into the interconnect ground wire. If the DAC has a two-prong plug you can try reversing it, sometimes this helps. You can also try running the power cables close together for as long a distance as possible, sometimes that helps.
If there is still no noise with the DAC connected to Crack, then connect the computer. The same comments as the above paragraph apply. The computer is likely connected to other line-powered devices such as a router or a printer, so you can try disconnecting them to further isolate the problem.
Hi Paul
These are the facts as I understand them right now.
1) Amp with nothing connected - No unusual noise
2) DAC connected to Crack, but no USB Connected - No unusual noise
3) ODAC connected to USB on Desktop Computer, connected to Crack - Noisy
4) Bifrost connected to USB on Desktop, Connected to Crack - Noisy
5) ODAC/BiFrost Connected to Laptop via USB - No Noise
6) ODAC to Headphones directly, connected to PC or Laptop via USB - no Noise
7) BiFrost Connected via SPDIF to Crack - Slight noise - Not as bad as via USB
8) ODAC connected to PC via USB then Connected to O2 AMP - No Noise
9) ODAC Connected to Laptop via USB then Connected to O2 Amp - No Noise
10) Noise from 3 doesn't seem to change as I adjust the volume knob on the crack
11) Noise from 3 doesn't seem to change if I remove one of the RCA's or the other, or if I swap them around
12) Noise from 3 not affected by type of music playing, or sample rate etc.
13) Noise from 3 can be drowned out if the volume is loud enough (Music
14) The Music coming from the crack in 3 sounds Excellent, just the buzz in the background
15) Noise from 3 moves from right hand to left hand depending on how far the headphone is inserted into the jack.
I have tried to troubleshoot this as methodically as I can...
