Skipperrik
I have a DAC that has an excellent remote volume control. Since my furniture arrangement requires me to sit 15 feet away from the stereo I take full advantage of the remote and seldom touch the volume control on the amp. After contemplating many changes to the stock volume control in my Crack-a-two-a I've decided that the most efficient solution from both sound quality and cost perspectives would be to eliminate the volume control and balance pots. Since I only have one source, I may as well eliminate the selector switch too and remove all three devices from the signal path.
Here's the proposed change:
The combined resistance of the volume, balance and input switch is 100k + 30k + 30k = 160k. Is that correct? I also want to reduce the volume to a more controllable level so 200k resistors in each channel might be the appropriate amount. One end of each resistor would be soldered to the signal terminal of each input jack. The red and white signal wires would be soldered to the other end of the resistors. The red (right channel) signal wire would be soldered to terminal 4 and the white (left channel) signal wire would be soldered to terminal 12. The ground wires from the RCA inputs would be combined and soldered to terminal 1.
Does this sound feasible? Am I missing anything?
Thanks for any comments!
