Mucker
Member
Hey all,
I am really enjoying my S3X amplifier. Quite spectacular! I believe I want it to be strictly a headphone amp and have some questions. Most of my headphones are terminated with 4 pin XLR male plugs. I've been using the XLR to TRS adapter but would sure like to plug the phones in without the adapter.
If I were to install an 4 pin female XLR panel mount jack:
1. Is the jack body grounded to the chassis? (Do I need a specific panel mount jack?)
2. Would the wiring from the output transformers to the jack be routed like this?:
1 .... L+ ..... white / green wire
2 .... L- ....... green wire
3 .... R+ ....... white / brown wire
4 .... R- ........ brown wire
I read about needing resistors routed to ground from each jack pin but the more i read, the more confused I became.
Could someone please tell me the exact wiring and resistor placement? I plan to leave the speaker taps and wiring in place but not connected.
Thank you!
Greg
Thank you!
Greg
