Very faint hum
Can you double check the output of the 6.3V DC supply on the power supply board?
If that looks good, clip lead the center lug of each 6C45P socket to the ground buss wire and recheck to see if the noise is still there.
Remove those clip leads and clip them between terminals 5 and 10 on each output transformer (where the teflon wires connect).
If the original test reduced the level of hum, that is indicative of noise being picked up in the wiring going from the RCA jacks to the selector, attenuators, and tube sockets.  If the noise is not dependent on the position of the attenuator (which you indicated before), then I would be suspicious of layout issues.
The Mainline is exceptionally sensitive to layout, and any deviations present the possibility of problems, so this may be a rather difficult issue to track down.
Just to be sure I clipped the correct wire from the 6C45P socket. It's the red and white wire going to the bottom tabs of the attenuator correct?
Also what do you mean by clip leads of the wire between 5 and 10?
Should I be rerouting the bottom tab of each attenuator to terminal 5 and 10?
Yes, those are in the correct spot for the first test.
For the second test, move each clip lead to connect terminal 5 and terminal 10 on each output transformer together.
Is terminal 5 on the output transformer the tab with the red wire connected? In the manual it is showing that both solid red and solid blue wire are terminal 1
PB the clips at terminal 5 and terminal 10 fixed the issue! No hum at all. I was also getting a louder hum at start up which would disappear after a couple seconds but that disappeared as well
That didn't actually fix anything, it's just another test.
The next test is to disconnect the end of the 10uF cap that goes to the red wire leading to each output transformer, then check for noise again.
Lol yes I just found out I wasn't getting any sound.
Should I leave the clips there or remove them when testing the 10uf cap
There is a hum when removing the side where there's a red lead going to the OT of the 10 uf cap. I think it also became slightly louder as well
Now you'll want to move the amp to see if that changes.
This, to me at the moment at least, indicates the output transformers are picking up some noise from somewhere.
