Hey gang,
I’m in the middle of building a tube guitar amp with a regulated supply just for the preamp section, and found this little gem: the LM317LM. It’s an adjustable 3-pin regulator that can output from about 1.2 V to ~37 V depending on how you wire it. Since I’m still learning and this is my first semi-serious amp build, I wanted to run a few things by you seasoned folks:
I’m planning to use the LM317LM for the +12 V filament supply (instead of raw DC from the power transformer) to keep hum and voltage drift down. Does that sound like a solid idea for tube filaments? For the resistor divider to set the output, I read you need just two resistors. Any good rule-of-thumb values you use for filter caps or layout when using this regulator in audio gear? Since this is part of a guitar amp and we care about noise, did you ever run into hiss/hum or regulator-related noise with a LM317 (or similar) in audio builds? Would an LM317LM be “quiet enough” for a preamp rail?
If any of you have used the LM317LM (or LM317 series) inside guitar or audio builds, especially tube amps or DIY pedal-amplifiers. I’d love to hear your experience: what worked, what you wished you did differently, or what you’d avoid next time.
Thanks in advance for any wisdom!
Cheers!
Cheers!
