MIKELAP
Well i found the problem it wasnt with the adapters it was with the tube i used a Russian 6H9C tube and for some reason thats what happened i tested the tube it tested good so i tried the other Russion tube of the pair and same thing happened low volume and it also tested good weird so after that i tried a Kenrad vt-231 and everything is perfect so i dont understand ill go check data sheet of those Russians probably the problem is there .ThanksJamieMcC said:I used a 6sn7 adapter in my Crack for a year or so and rolled a number of 6sn7 tubes and didnt find any that lacked volume using Beyer T1 or HD800 my adapter was essentially plug and play. So its odds on that its either a problem with the adapter or the tube. Maybe get a inexpensive new 6sn7 to try. I do remember when looking into using the adapter myself that one or two Crack users on headfi were having noise issues with their adapters but mine worked fine from the off.
