attmci
Francisco said:The one on the left is the one marked Amperex, and the one on the right is supposed to be made by Mullard.
Agree the left is a GE (with GE dots near the bottom).
Any code on the right tube?
Francisco said:The other i believe it is a Mullard, it flashes on power on.
Other markings:
teamrushpntball said:Quick question for everyone, I picked up a Philips Miniwatt E80CC and think something is faulty. I was under the impression the gain was higher with these than standard EC82 tubes. Mine is incredibly quiet unless my volume is near maxed out. Is this normal?
TurbOSquiD77 said:So I was looking at 6SN7's and came across this:
https://www.tubedepot.com/products/sylvania-vt231-6sn7gt-1945
I feel as if one should be careful about who they buy from, and their pricing. Are these Sylvania's really worth this much? What are the typical TOTL 6SN7(GT)'s that are usually favored?
Regards,
-T
calmiswar said:Hello All,
I recently purchased a 12AU7 Telefunken tube, the seller tests on a Maxi-Preamp 2. Between the 2 triodes, I see A has a gain of 15.5 and B has 17.2.
I saw this after I purchased, is this normal or have I purchased a lemon?
Thanks.
Thanks a lot for the reply! That is great to hear.Tom-s said:This is perfect! I've used Telefunken measuring 13 vs 8.5 and that tube sounded perfectly normal.
calmiswar said:I recently purchased a 12AU7 Telefunken tube, the seller tests on a Maxi-Preamp 2. Between the 2 triodes, I see A has a gain of 15.5 and B has 17.2.
Thank you. I was playing with the balance feature on my Fiio X3ii and I can't really tell the difference of 1 dB.Caucasian Blackplate said:That's a little less than 1dB of difference. It will likely be a little audible, but not intrusive. It's certainly not abnormal.
calmiswar said:Thank you. I was playing with the balance feature on my Fiio X3ii and I can't really tell the difference of 1 dB.
Just thinking, can I compensate for the dB difference in the input tube triodes using the balance feature?
Our first preamp kit, the Foreplay, offered two dual mono volume control pots as you described. I built several over they years, and I found it extremely tedious and difficult to ever get the channels balanced, and once they were balanced, I would never really want to adjust the volume because then I would have to start over and rebalance the channels at the new level.Lawrence Ho said:I have seen someone modified his crack so that there are two individual, separate rca channels, and two volume controls (alps blue velvet) of course.
MIKELAP said:First time poster here. About using a 6SN7 in the Crack i got myself a 6sn7 to 12au7 adapter .it works alright but problem is sound level doesnt get very loud is there a modification that has to be done to use this tube .i was under the assumption it would work ok with adapter kinda puzzled .i heard of guys using this tube .
We use essential cookies to make this site work, and optional cookies to enhance your experience.
