Do you mind to use an adapter?azeendeen said:Can anybody recommend me tubes to get with a budget of 100usd? I would like a slightly v sound with bigger sound stage. It's just that I don't much about tubes since this is my 1st tube amp .
Paul Birkeland said:The ECC32 is a 6SN7 and should work with the stock Speedball.
attmci said:Hi, BZ58, the Syl 6SN7W is one of the best 6SN7 tubes (military grade tube, long life, very very quite). They can be used as driver tubes with an adapter on Crack (same gains, but draw 0.6A).
http://www.fourwater.com/files/hist6sn7.txt
Maybe he used a really dead 6SN7 or had other issues with the amp.cddc said:I don't remember where I read it, but someone reported the wirewound resistors under the heat sink became very hot and wires next to them turned brown after rolling in a 6SN7. So I was kinda concerned about 6SN7 tubes.
Paul Birkeland said:Bangy Bang Tubes does not have a particularly savory reputation, I'd suggest doing some research before spending any money there.
Although these are labeled as "Stromberg Carlson", they are Tung Sol 6080s.
Tung Sol 6080s
This has one Tung Sol and one GE:
Tung Sol & GE
Paul Birkeland said:I would recommended talking to Jim at vacuumtubesinc.com, or Jim at McShane Design.
It takes a ton of time to sort through all the listings on eBay!
This is a pretty decent listing:
https://www.ebay.com/itm/4-PCS-CSF-6080WA-6AS7G-Chinese-6N5PJ-TUBE-VALVE-french-made-one-of-the-best/173722865320?hash=item2872b08ea8:g:HSoAAOSwwTla~7iv
Tom-s said:Rule no.1. buy cheap. ;D
Get a cool coke shaped bottle for Crack.
The output tube i recommend to try (prefer it over RCA 6as7g) is the Russian 6N13s https://www.ebay.com/itm/382880263018
Pair it with some locally found Ecc82/6sn7.
A Tungsram E80CC is a nice tube in a speedballed Crack.
https://www.ebay.com/itm/142545441812
Edit: La Radiotechnique is a Philips tube. Ecc82 was made in the Suresnes Philips factory, like ECC40.
I would e-mail him, that gives him the time to get everything together without the time crunch of being on the phone.cddc said:These French 6080s seem to be a great deal. Thank you very for the link.
I will also give Jim a call sometime. The problem with vacuumtubes is that they list tubes and prices on their website even thou they probably do not have most of them. So it is really hard to find tubes from them unless you give them a call.
Nope, you have to use a 6SN7GT to 12au7 adapter. So the heat is not a problem here.cddc said:Cool.
I don't remember where I read it, but someone reported the wirewound resistors under the heat sink became very hot and wires next to them turned brown after rolling in a 6SN7. So I was kinda concerned about 6SN7 tubes. But it's okay now. Thanks very much.
Hopefully I won't get into the trap, or at least not too deep into the trap. We'll see.![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
