Crackerjk41
Hello, I have a bottle head crack that has worked fine for years but then I had to put it away for a while and I recently got it back out and turned it on and there was no sound. Both tubes lit up (Both sides of the smaller tube lit up too)
I did a resistance check, failed, and since I already turned on the amp with insufficient resistance, I figured I’d go ahead and do the voltage test. The following are my results for resistance and voltage
Voltage
1) 1.16
2) 1.16
3) 0
4) 1.16
5)1.16
6) 0
7) 0
8 ) 0
9) 0
10) 0
Resistance
3) .1
8 ) .1
12) .2
14) .2
20) .1
22) .2
Ground .1
Everything else did not get a reading. My multi-meter beeps when there is a connection but it did not beep for 1,2,4,5,6,7,9,10,13, RCA Centers, B3, B6
My goal is to get it back up and running so I can install a speedball kit so any insight would be greatly appreciated! Thank You!
Voltage
1) 1.16
2) 1.16
3) 0
4) 1.16
5)1.16
6) 0
7) 0
8 ) 0
9) 0
10) 0
Resistance
3) .1
8 ) .1
12) .2
14) .2
20) .1
22) .2
Ground .1
