amritdesai
Member
I started this thread so I figured I'd give the Hammonds a shot.
I mounted the Hammond 156L inductors to the amp base with their coil axis perpendicular to the power transformers. I measure the AC voltage between the choke wires without connecting anything with a reading of around 6mVrms for both inductors. I tried moving them around and changing orientation but the reading was pretty consistent. I soldered the chokes in place of the last 130ohm resistors.
All resistance checks were within range - some of the voltage readings were higher. I performed these checks with the stock tubes.
Terminals
1. 370 VDC
2. 407 VDC
19.407 VDC
20. 370 VDC
I tested the amp on a spare set of speakers and everything sounded fine. I'm not sure if there is any audible difference or benefit with the inductors. Previous to making this change the amp was sounding wonderful - very open, sweet and textural.
After a day of listening I'm finding much of the brightness and sparkle has been replaced with a more neutral tone - overall a little less dynamic. The image though has tightened up quite a bit. Likely, things will open up more over time.
Terminals
1. 370 VDC
2. 407 VDC
19.407 VDC
20. 370 VDC
