Moderator
You mean, I think, the oldest ones from before the Specos. Your transformers are very similar to the Speco, and should work about equally well.
Wormwood said:Now my question - would the Head-Quickie mod run AKG Q701? Or is this mod more like a mini Crack?
cvandyke said:I have an older pair of the Speco T-7010 transformers which were removed from the original Paramours during an upgrade. These older transformers did not have the same color coding as the new production ones. For installing these in my Quickie, I developed the table below and thought this might be useful for other bottleheads with older Speco transformers.
--Chris
{Editted from original post which was badly worded}{Editted again to fix stupid error in table}
Paul Joppa said:Here is a first draft of wiring for the two versions of the Speco T-7010 output transformer. This is for the stock setup (not optimized for choke or PJCCS loads). I'll update it when I have done some more measurements and analysis.
They don't quite have the ratio that you'd want for this purpose.boulos said:Hi,
I have a pair of WE 111c isolation transformers. Can I use them as output transformers for headphone use for the Quickie? (they're too big so they would have to be mounted to a separate box).
boulos said:Is this the case even when the transformers are wired as 600 -> 150 ?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
