InfernoSTi said:bainjs said:The MB Quart 400's are available again. Check the discussion in Headphones for more info. They are 300 ohm units. Great sound and comfortable.
Where are they available, please?
If you look at SPaulMac's picture and description on page 2 of this thread, that is the one you would want to follow for 300 ohm cans. I think. Brown wire goes to headphone jack right to ring left to tip and make a wire from ground of the headphone jack to the the grounding bus wire on the quickie. Tie red 8 ohm wire to black common wire on the other side of the transformer. Solder the black wire (labeled 0 on the same side as the red 8 ohm wire ) to the ground bus wire of the quickie. Solder the violet wire to each of the output jack solder cups. Tape off all other leads. Should work fine.bainjs said:I tried wiring the new version of the speco 7010 with mixed results and have confused myself thoroughly.
Would it be possible for someone to give me the correct wiring for a set of 300 ohm headphones?
I need basic instructions like "blue goes to input jack, red on secondary side goes to..." and so on. Which colors do you now tie together since there is no white wire any longer?
Thank you for the help. I had a chance to listen to two more albums last night. The 60 ohm cans work fine on the .25w tap plenty of deep bass and detailed highs. After further review, it might be missing a slight bit of lower mid-range and upper low-range. The cans could just be flatter than the mid-range heavy speakers that I am used to. I have no reference for the headphones, since they are brand new. Overall I am very happy.Paul Joppa said:This is excellent news - thanks for posting it! I'll try to find some time to measure the transformer more carefully, since it appears to be worthwhile after all, at least in this application.
SPaulMac said:I finally got around to ordering the Edcor EM0735 transformers. Now that I have them before me, I have to admit that I probably have no business with a soldering iron in my hands. I have no clue as to how to hook the new transformers into my Quickie's circuit in place of the Specos. I'd imagined something like the signal ground going to both the C.T. and Common taps on the primary and secondary; the signal going to the 8K ohm tap on the primary and the output going from the 250 ohm tap of the secondary to the headphone jack, but I don't really look forward to smoking my little Quickie. I'd be very thankful for any help I can get on the proper wiring procedure for this transformer. The pin assignments for the EM0735 are as follows:
Primary
Pin 1 8K Ohm
Pin 2 Center Tap
Pin 4 8K Ohm
Secondary
Pin 5 250 Ohm
Pin 6 32 Ohm
Pin 8 Common
Stephen
Stock or modified, I recommend experimenting with adjacent output taps.bainjs said:...
Paul: Do you think there will be changes if the PJCCS module is installed? ...
I rewired last night with good results. I originally had the 8 ohm connection wired like the old one with 8ohm tied to common and 0 tied to ground, Now it is exactly as Paul has it in his diagram. Does seem to have more volume. Also, maybe a bit more balanced sound. Tried all adjacent taps as suggested and tried both chokes and pjccs. Blue wires on output and brown wires on headphone jack produce the absolute best sound and most volume for my 60 ohm cans.bainjs said:Thank you Paul for the diagram. It made wiring it up much simpler. Also, thanks kkinc to your suggestion. They both worked pretty well, however, I think Paul's version has a tad more volume.
Paul: Do you think there will be changes if the PJCCS module is installed? I have one in my Quickie.
Joel
denti alligator said:I've upgraded my SEX with MQ iron. Can I use the old transformers to convert a Quickie to a headphone amp?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
