SR45 amplifier
PJ came over to the island this week to pick up a bunch of parts. I believe they were mostly for power supply testing (big resistors to simulate the load, etc.), but output iron and a sizeable chunk of wire was picked up as well. It is my understanding that the power supply is being built on the chassis rather than breadboarded, so the amp must be starting to look like an amp!
Semi-local - door-to-door is about 90 minutes, longer in the summer when the ferries are full of tourists.
Josh's description is accurate. I need to put the fully loaded PSU output on the scope to know which regulator chips I can use for the filaments, and to know how much current I can take out without overheating the PT-7. Then I can finish the second large PC board, which has all the heat sinks.
I had hoped to do all that without using the full chassis, but there are so many wires with high voltage or current it just looked like a disaster waiting to happen, so I'm doing it the slow but clean way. Not really my natural style; there's a reason Doc doesn't usually let me build stuff by myself  :^)
Hi PJ.  Thanks for all the updates on the SR45 amp project--we appreciate it!
A quick question--have you and Doc decided for sure whether this amp will be an actual BH product?
We have not talked strategy at all.
But I expect it will follow some non-traditional path, like crowdfunding or limited production run. Like the DAC, it's not cheap and will appeal to a smaller audience than our more mainstream products. I can see a semi-kit also - the main PC board will be pretty large (for Bottlehead) and has an awful lot of components on it, which will make debugging through the forum a challenge. Dynaco did this back in the day.
Back-ordered parts (from March or so!) finally came in a couple weeks ago.
Yeah, it's going slow - I keep getting distracted with other designs, most of which have not yet come to the point where we want to say anything about them.
Hi Paul, any updates?  Dan really doesn't want to bring those other products to market. What could be better than a new SR 45 amp ;)
We will be shooting manuals for two to three new products this month alone.
PJ's commitment to a strong, reliable implementation of the SR-45 is unwavering, and since the scope of this project is beyond any kit offerings we currently have, there is no real prior precedent for how long such a project will take to complete.
You are correct PB, but I can poke the bear once per month :). You guys are amazing and I'm thankful for what you bring to the world.  Nothing here but a dedicated fan base reinforcing a desire for the ultimate design.
Other projects - mostly getting my late mother's estate through probate right now. Long story, but coming to a close finally.
There's a lot of developments going on at Bottlehead, and the SR amps are related to those developments, so they are not orphans even if it seems like it right now.
