You can use two 1N5820 diodes to make a full wave rectified supply to feed the #45, then a small value resistor, then a 10,000uF cap. The value of the resistor and the actual 10,000uF cap you use will interact together to result in an optimal value, but I think you could start with a 0.22 ohm/3+W resistor to see what happens.
