Greetings everyone,
My friend built his Crack and got it working and he loved it. Later he decided to install the Speedball upgrade. He wasn't able to get it working so he came to me for help.
I've spent the last few hours scouring the forums looking for posts that would help me solve the problem, but I can't find any that solved the problem I'm having.
Here is my attempt to explain the issue.
When he first turned it on, he saw smoke and turned it off right away.
Here are the symptoms that I can describe.
When I turn it on:
I have checked and reflowed all of the transistor joints on both the main board and the smaller boards. I also reflowed all joints that hadn't penetrated both sides. I also looked everywhere for a short, solder bridge, or misconnected component. I couldn't find any.
The voltages are as follows:
I realize that some of those are way out of spec and aren't right, but I (being new to tube amps, and amps in general) have no idea where to sart.
Any help you can provide will be greatly appreciated <3
edit: I forgot to sign my name. I'm Paul Klopping! Thanks again!
When I turn it on:
- the A3 and A8 LEDs slowly fade on, and then A3 slowly fades to dark.
- When A3 and A8 are fading on, the LEDs on boards A and B fade on, but are dim
- Once A3 fades out, the LEDs on the large board nearest the transformer fade on, but the other set nearest the audio jack never turn on
- The 270 ohm resistor that sits across the transformer heats up and creates a burning smell
- T1: 55 - Starts over 200 and then falls
- T2: 63 starts high and then falls
- T3: 0
- T4: 65 - starts high and then falls
- T5: 21 - starts over 200 and then falls
- T6: 0
- T7: 27 - starts low, jumps to around 87, and then falls
- T8: 0
- T9: 19 - starts lower, slowly reaches 19
- T10: 0
- T12: 0
- T13: 215
- T14: 0
- T15: 215
- T18: 76
- T19: 75
- T20: 0
- T21: 223
- A1: 15 - starts around 75 and then falls
- A2: 0
- A3: 2
- A4:
- A5:
- A6: 80 - starts around 200 and falls
- A7: 0
- A8: 2
- A9: 0
- B1: 78 - starts around 200 and falls
- B2: 207
- B3: 16
- B4: 20 - starts higher and falls
- B5: 78 - starts around 200 and falls
- B6: 20
- B7: 0
- B8: 0
