Sorta homemade EL84 Amp
earwaxxer said:
got to love that clean build! That, to me, is the real beauty!
I appreciate that.  It took me 10 hours of concentrated work (while doing laundry!) to finish it.  I was designing and building on the fly trying to work with the materials I had on hand(Radio Shack), keep everything safe, neat and mounted in a way that won't fall apart.  I was in the zone and not even an old and constantly dying rechargeable drill was going to stop me from getting it working.
Caucasian Blackplate said:
I don't think you're going to need 220uF in those positions with the ESR being that low.
I think I might be more inclined to leave the two 220uF caps stock, but install the 110uF Clarity caps to start
If I'm going to put film caps in, then I want to go all the way.  My ST35 amp sounds so much better without the electrolytics it's insane.
So you're saying if I were to do that I wouldn't need as much capacitance?
  I see on each channel a couple of 220uF and a 47uF.  I'll have to live with that 1000uf cap.  There's also a 22uF cap by the C4S boards.  Is that in the signal path?  I'm unable to review my manual for some strange reason.
The 22uF cap is pretty well isolated by the C4S load, though things like this are "supposed" to not make a difference, reality seems to say otherwise.
The 1000uF/35V has some substitution options, there's a Nichicon 1000uF/25V ES, 1000uF/35V FG, 1000/35 KA, 1000uF/25V KZ, etc.
One can drive themselves insane trying to pick these things...
Hey Rob, not sure if you saw this review on electrolytics =)
It might help a bit.
http://tech.juaneda.com/en/articles/electrolyticcapacitors.html
Eric
Eric
Thanks Eric.  That was interesting.  And of course the best caps are the hardest to find.
