Smashup Voltage [resolved]
What amplifier are you using and what speakers are you using? (or alternatively how much gain does your power amp have any how sensitive are your speakers?)
Yeah, I figured you either had a ton of amplifier gain (20+dB) or highly sensitive speakers, and you have both!  I would use some Harrison Labs -12dB attenuators at the input of each amplifier to reduce sensitivity a bit, or consider a lower gain/lower power amplifier.
Long time ago I purchased the last two suductor amps kits that you sold, would this work along with a Thorens turntable and the Eros that I build already?
t
The Seductor will knock the noise down by about 12dB.  You may prefer the Seductor and some -12dB attenuators to really knock things down.
I went from 2 amps to 1 and the noise went down a little but I noticed that there is noise even without the smash powered up. its that normal?
they are two umbilicals, one for the filament of the 4p1l's that is two wires and the other has 3 , one is ground and the other two are both 150v, one for each channel .
That is a potential source of noise.  Ideally you would have the chassis plates connected together through their own wire in the umbilical and that would be hard grounded to the E lug on the IEC power entry module, then the audio/power supply ground would run separately and you would put the antiphase diodes in the amp section between the audio ground and the chassis.
