Put a bad tube in and saw a little smoke after a minute or two
sbelyo
I broke a cardinal rule and put in a pair of tubes before testing them.  One was fine, the other had grid leakage and was shorted.  The tube was in there for two minutes total, I plugged in my headphones and had music from one side and crackling from the other.  I went to unplug the phones and saw a little light smoke from the vent and a funny smell.
I powered down and removed the tubes.  All the components looked ok but the smell seems like it came from the C4S board.  I installed new tubes and played the amp for an hour or so.  It seems fine and plays normal so I think I'm ok.  What should I check?
Has anyone ever fried anything from a bad tube?
I would run through the resistance checks in the manual to make sure none of the resistors got toasted if there was a short.
I once stumbled upon a new tube that had the filament wiring shorted against the grid, it made a rather loud bang when the tube warmed up and started to conduct!  Since then i always run new tubes through my tube tester before they go near the amp.
