Moderator
Notes interspersed
I. Component Value Changes
Driver Cathode: Changed from 274 ohm to 180 ohm (Increases 5965 current to ~10mA).
That's for 150v at the 5965 plate, a compromise when direct-coupled. To use the Stereomour upgrade kit, you'll want more like ~200v, which alters the resistors.
C4S Board R1: Changed from 237 ohm to 150 ohm (Sets C4S current to match 10mA target
2A3 Cathode: Fixed at 3k ohm (Two 1.5k ohm Mills MRA-12 in series).
Depends on which circuit you choose - that's not clear yet.
Main Dropper Resistor: Changed from 1k ohm to 2.2k ohm Mills MRA-12.
Why?
C4S Protection (New): Added 15k ohm 12W Mills resistor between supply rail and C4S input to pre-drop voltage.
Depends.
Grid Stopper: Changed from 1k ohm to 681 ohm.
OK
II. Topological & Wiring Changes
Driver Power Feed: Driver stage is fed directly from the power supply rail (after 2.2k dropper) rather than being tapped from the 2A3 cathode.
For SRC4S?
Standby Implementation: SPST toggle switch breaking the High-Voltage Center Tap to Ground. A 100k ohm 2W resistor is wired across the switch lugs.
Power Supply Filter: CLC configuration using DC Link Capacitors. Each cap is bypassed with a 0.1uF high-quality film capacitor.
AC Input Snubber: 1 ohm 10W Mills MRA-12 + 0.1uF X2-rated Safety Capacitor at the IEC inlet.
Rectification: Solid-state Schottky diode bridge
A full bridge would double the voltage, to 900vDC - you don't want that. Just use two diodes.
-PJ
Why?
Depends.
OK
For SRC4S?
-PJ
