Balanced output is not necessarily from a fully differential output. As sweet and bright a guy as Allen was, he used to make me crazy by mixing the definitions. He was talking about push-pull circuits inside the amp (or as George Wright use to call it, push and shove circuits).
Balanced connection simply means that the impedances are balanced between the signal wires at both the source and load end of the cable. It's a technique for wiring equipment together with cables the improves the common mode noise rejection, not an amp topology.
