Distortion when connecting to new amp
El Tel
Member
Hi Everyone
Can anyone shed any light with this ?
I've an upgraded Moreplay, which has been connected to both an Icon Audio 300b amp and also an Optonica SM-4646 (not at the same time) with no problems at all. I had the volume on the Moreplay at full gain and adjusted the volume on the 300b or the Optonica.
I've now acquired an Advance Paris A10 Apex amp and when I connect the Moreplay to it via Aux 1 in the same way the sound is distorted, any ideas ?
Many Thanks
It's possible that there's a limit to the amount of voltage you can feed into the input of the A10. If you have a relatively potent source and you turn the volume of the Moreplay up to full blast, that is an unreasonable amount of signal relative to what a designer of an integrated amplifier might expect.
