lazyoliver
Hello, I've had my crack with speedball for about 4 years now but while trying to fix a faint ringing in the left channel (which I believe was caused by a microphonic tube) I've ended up with a crack that only makes buzzing sound that's uncomfortably loud and occurs with the volume pot all the way down.
To fix the ringing problem I purchased a 12BH7 to replace the microphonic 12AU7 I've been using. When I put in the new tube and turned the crack on I thought I had fixed the problem and the crack sounded as great as always for the first minute. After that first minute though, white noise started to crescendo in the right channel and I turned the amp off. I went back to the 12AU7 hoping it was something related to the 12BH7 but no luck, the white noise was still there. I then proceeded to clean the tubes and their sockets as well as reflow the solder joints for the right channel. The white noise remained. I then noticed the speedball boards where a little dirty from flux and I then cleaned that off with some rubbing alcohol and then tried turning the amp on one more time. Now as soon as the headphone makes contact in the headphone jack I get a loud buzzing sound.
I've double checked my wiring for shorts or cold solder joints but nothing sticks out and I'm not sure where to go from here. Does anyone have any ideas?
