4krow said:One thing that I would like to mention about the Telefunkin tubes, is that near full volume, they have a lot of distortion. To be fair, I rather think that it might have to do with something else that I have done with the circuit. So far, I have changed the original volume control to a stepped attenuator, but I'm thinking that's not it. I have changed out output caps twice, and the problem has occurred with both caps. Other than those two things nothing much has been done. That is why I tend to think that these tubes might be the reason. Ok, now I have to switch back to the originals just to check.
Paul Joppa said:The Quickie has fairly limited output voltage capability. Into a high impedance load, clipping would be expected at 3.5vRMS with fresh batteries, 2.3vRMS at the end of battery life. For myself, I'd prefer to keep it below 1.0 volts to avoid audible coloration - but it depends a lot of what the meaning of "audible" is! For comparison, BeePre or Foreplay should put out 20vRMS before clipping.
If your amp/speaker combination needs more that 1vRMS peaks, Quickie can run into trouble.
Your logic is good - live long and prosper!4krow said:Let's work it backward from the speakers, no numbers as such just logic. The more sensitive the speakers, the less they will need from the amp. The less that the amp is required to give out in power to a speaker, the less the input signal needs to be. If the Quickie falls into that premise, then it is fine with giving it's lower output. I'm not learned enough to get into figures here, but that would be my logic.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
