pickles3201
Hi, so a long time ago I tried assembling a Bottlehead Crack+Speedball. I honestly don't remember if my crack pre-speedball worked or not since 1. I don't recall hearing a negligible difference and 2. there was a second LED by the 9-pin socket that I remember not knowing existed (so it probably wasn't lit?). At the time since I missed the second LED, I thought it worked and so I went along with the speedball upgrade. So here we are present day.
If you see my previous post history I posted about resistance failure checks on pins 7, 9, B3, and B6 about 2 years ago. I recently did another resistance check, and those 4 pins still read as over limit. But I actually searched it up, and I saw one post where Paul said it was fine because the Speedball changes the resistances. So are these 4 pins no longer a concern then?
And for the LEDs, a couple of the LEDs were actually on until I 'resoldered' pin A7 (voltage failure fix attempt) by adding what is probably considered too much solder, and so now no LEDs light up.
It's pretty late right now so I'll try to remove the excess solder tomorrow, but is my crack cucked or is it completely plausible that too much solder on one pin could lead to all LEDs not lighting up?
Assuming that the above problem is fixable, I did have some pictures of the LEDs before I screwed it up with the solder.
The 2 LEDs by the 9-pin socket were lit, and the 4 LEDs on the big circuit board were lit, but fairly dim in comparison to the 2 LEDs on the small circuit board. And as you can see by the image, the other 2 LEDs on the small circuit board don't light up.
In terms of voltage for the small board (before solder screw up), OA and OB were both at like 375 volts, so that's why I tried resoldering A7 (voltage was about 2 volts) but not A2 (voltage was 0). After putting a bunch of solder it's still at 375 volts. I'm definitely removing the excess, but I'm curious (assuming that removing it works) as to why too much would cause such an issue.
Any help is appreciated, thanks!
