A little while back I picked up a Foreplay I kit that had been sitting in someone's closet for the last 30 years. I'm just getting starting with tube electronics, and putting it together was a great learning experience. It came with the Anticipation and Sweetest Whispers upgrades, though I only installed the former. Once I had it running in the original configuration I started thinking how I could make it better for my tastes and purposes. I built a new case for it out of thinner walnut with a lower profile, moved the PT underneath the chassis inside the case, moved the input and output jacks to the back of the case, replaced the dual volume pots with an Alps Blue Velvet stereo unit, added a choke in place of the second resistor in the CRCRC network, replaced the coupling caps with Solens, added 100k resistors at the outputs to attenuate the output level a bit (without them the gain was just ridiculous when matched with my Lafayette KT550 power amp) and got a matched pair of Tung Sol reissue 12AU7s.
The thing sounds great, but it's got a pretty pronounced 60Hz hum. I tried to replicate the grounding scheme as much as possible when moving to the new chassis, but with the move of the i/o jacks I did have to make some changes. Like I said, I'm more or less a complete beginner, so I'm not sure where to start with tracking down the hum. It’s in both channels, is unaffected by input source or volume control, though there is an additional, slightly louder 60hz buzz over the top of the hum when I touch the volume pot. I’ve also tried moving things around (various wires, the Anticipation circuit boards) with a chopstick and no movement seems to make any difference in the volume of the hum.
Any suggestions for things to look at? Any obvious mistakes I've made with the grounding scheme? Pics attached. Thanks very much for any input.
