Woah, yeah, there's a problem there!smallmany said:I forgot to connect the pc to the amp ;D
The pot reads 1.61-1.62v
Terminal 6 reads 14.6v
Terminal 10 reads 1.83v
So all four terminals on the pot gave ~1.62V? That's a good sign.
Can you very carefully repeat the measurements, but this time measure the AC voltage at T1 and T5? Most meters should still pick up on the 60 Hz AC component and block the DC. If you see something like 12V AC, that's a valid measurement. If you see something a lot higher, then let me know and we can tweak things to get your measurements.
