Just a troubleshooting suggestion, but the fact that you are able to repeatedly create these symptoms makes a big difference. Next time you get a chance to work on your amp run it upside down in the base, or on books, etc. The key is to have easy access to the bottom so you can perform a complete voltage check while the problem is occurring. Post any voltages here that are out of spec and someone a lot more knowledgable than me will help you sort it out. If the voltages are all good when the sound stops then I'd look long and hard at the signal path wiring. Paul B can help you trace that by taking measurements with your meter while playing a test tone.
And if you can't reproduce the problem with the amp upside down you'll just have to build a clear cover and run it that way from now on! Just kidding
. If you can't reproduce the problem with it upside down that provides clues too. That would send me looking for a mechanical issue caused by gravity when the amp is in the base.
Don't get discouraged. PB and the rest of the BH team are great at solving these tough issues and won't give up until your amp is fixed.
