I have a couple of amp projects about to get underway that will be wired for balanced power as I'm now using an equitech balanced power system. Basically what I'm doing here is to wire both hot and neutral as hot lines with their own fuses and switch poles, the question is how does one calculate the fuse rating for this scenario where each incoming lead has half the voltage -- 60-0-60?
If anybody has done this and knows the answer, please let me know -- my gut tells me that I should use fuses of the same rating, or maybe just slightly lower. It's just that some of the fuses are fairly low to begin with and the next lower fraction may be too low.
-- Jim
-- Jim
