I haven't seen any mention of nippers with a lead catcher, but after a few years of using the conventional kind, and then getting a pair of these, I find them indispensable.
https://www.amazon.com/Tsunoda-TH-125NC-Cutting-Pliers-Catcher/dp/B073V2X71S/ref=sr_1_14?keywords=tsunoda+nipper&qid=1556936763&s=gateway&sr=8-14
They hold onto the cut part of the lead, cable tie, or solder, even down to 0.1 mm wire. I'd recommend them to any first time builder - I wish I'd had them when I built my first kit. I don't know what the pros think of them. If there's a downside, it's inseparable from the purpose of the tool itself: you have to shake or push the cut part loose from the nippers before cutting the next piece. Simply opening the jaws isn't enough. But that's a more than acceptable tradeoff for not having to hold a hand over the piece you're cutting to prevent it flying off. You can even ditch the safety glasses while using them.
