Crack finish. Volts problems.
michael30
Hello everyone
I finished the crack and checked the volts.
First of all,one of the LEDs do not light up.
These are the test results:
terminals-
1:  157.6
2:  173.7
3:  0
4:  174.5
5:  86.6
6:  0
7:  159
8:  0
9:  112.2
10:  0
I over checked all the wiring.. looks good.
i'm new so i can't point at the problem.
Ty for help!
Do you see both sides of the 12AU7 glowing?
Can you very carefully check the voltage on A8?
Generally this is not related to the LED itself, so resist the urge to reflow the solder joints around the LED, as excess heat can damage them.
Yes, 12U is OK as a ground.  Terminals 1 and 7 will fall into line based on the information we find from the voltage measurement at terminal A8.
That is generally indicative that the LED has been cooked and is no longer working.  You can connect a piece of wire between A3 and A8, then in all likelihood you will find that your voltages are proper.
If you can't tell which end is the cathode, it's not a good idea.  They also absorb moisture over time, and a garage is pretty humid.
112V is still a little high, what DC voltage do you see at A7?
Btw i meant Terminal 7.. but you got me.
anyway i read 0 for A7.
https://postimg.cc/jCSgK6tR
Thank you for fast respond.
The new reads:
1)  85.7
2)  179.4
3)  0
4)  179.4
5)  89
6)  0
7)  111.6
8)  0
9)  114.6
10)  0
Both LEDs glowing. https://i.postimg.cc/wTTy1ZCT/IMG-9761.jpg
Update Voltages after soldering wire a3-a8.
1) 85
2) 184
3)0
4)184
5) 0
6)0
7)113.5
8)0
9)116
10) 0
after soldering reasults.
after 30 min run.
terminals:
1)86.8
2)174
3)0
4)174
5)89.5
6)0
7)110.4
8)0
9)112.5
10)0
Yesterday i checked it with 235v.. now im at my brother house and i get around 223v from the wall.
Also I think can hear diff in volume between left and right ( left +1 -2).  not sure yet.
Those are working voltages.  You can check the Crack FAQ stickied on this board regarding channel imbalance at low levels on the volume pot.  It's not abnormal and there's an easy modification to fix that.
Hey Paul .
Just wandering... I wasn’t able to touch the chassis because it gets really hot, is that normal for the crack ? I only using 1/10 of the volume right now.. after 2 min I can’t touch it.
If the voltages in your amp are normal, then the temperature of the top plate is normal (provided you have also installed the rubber feet).
A stock Crack will produce some extra heat in the top plate around where the 3K/10W resistors are and the Speedballed Crack will produce slightly more heat overall under the plate, but less localized.
