Crack finish. Volts problems.
Hey there.
After some time with the crack I have a new problem .
Some static noises and chuckles that comes and go...
I tried replace rca + all cables, still there come and go.. also some really low background noise that always there but noting harmful. But the static and chuckle really annoying , what it may be ?
First hours used was dead silent .
Ty Michael .
This could be an issue of solder joints or potentially interference from nearby electronics.  Are you using your computer as a source with the Crack?
Computer/iPhone
But I did unplug all, left it only connected with my headphones and it didn’t stop.
For now it stopped .
I will update if it will come back . Also I will upload all my solders ..and re solder any points you will tell me.
Thanks again 🙏🏻
Michael.
Hey.
here is the photos. if something else needed i will update as soon as i see.
https://drive.google.com/open?id=1AIkd22uIUl4odWHvNJ6TgT_yk-UfVJlj
also i swap the 12au7 to cbs jhy 5814a from 10/1960 , for now looks like those chuckles and noises gone.
anyway i would like to fix any bad soldering.
Ty Michael
michael30 said:
Hey.
here is the photos. ...
Hi Michael - you should delete your posting of the Crack manual - I don't think BH treats it as public domain.
cheers, Derek
Yes, whenever it gets posted, we get lots of e-mails for "replacement" power transformers ;)
I'd sell them for $225 with the option to upgrade to the full base kit for just an additional $90.  ;D
cheers, Derek
I've found over the years that a lot of times swapping tubes will move solder joints that aren't 100%, which can make it look like an issue is tube related, but it comes back at a later time anyway.
You can also try this mod, which will help with external interference:
I have sent you an email asking for the speedball guide , . so it’s me. ::)
And from your answer i understand that all the soldering looks good.
I forwarded your e-mail to the replacement parts address to get you another download.
When in doubt about solder joints, just reheat them all.  This is what I do for any kit repair that I get in.  Reflowing all the joints in a Crack takes me 10-20 minutes at most.
I will do it , thank Paul. I have to admit again I've never encountered customer service like yours, maybe it's because of the country I live in, yet, I have to put it to your credit. Thanks and appreciation.
Michael
I check my voltages before 2 and 5 is 191v and 7 is 115v.
I rechecked my apartment outlets and it 240.1.
When I solder the power I did it for up to 235.
Do I need to change it? May it damage the amp?
The real problem is that I sometimes use outlets that give out about 228-235
And in my other apartment it’s 240.1 .
What do you think I should do?
After speedball, I’m satisfied, all working well with my cbs jhy 5814A.
The only thing that disappoints me is the stock 12au7 that making so much static and chucking,
I do not know the reason to it... barely used it, and can’t be use now because all of the unbearable noise. At least the cbs I dead quiet.
