What DC voltage do you have at terminal 21?
Yes, so the black wires on the balance control connect all the way back to the ground in the power supply. Yours are not connected. If the build was otherwise working properly prior to adding the upgrade, then this is a loose connection or a broken wire along the ground path somewhere. You can start back in the power supply at the last 220uF capacitor and measure DC voltage to the banded end of that cap, then follow the black wire that leaves there, and measure along the way. That will go into the upgrade board, then output of the upgrade board and into the amp. Follow the black wire around and measure DC voltages until you go from 0V to something else, then you'll find where this has been disrupted.I tried putting the black meter lead on a black wire on the balance control, same 397 volts. I don’t know what else to try…
We use essential cookies to make this site work, and optional cookies to enhance your experience.
