You definitely do have a blown power transformer.
When you get the replacement (shoot an e-mail to Eileen and be sure to provide a link to this thread), I would recommend doing the following:
1. Connect all the primary connections on the incoming AC side and check the AC output voltages as directed in the manual.
2. Hook up just the low voltage winding feeding the STP wiring going to the 5670 tubes and verify that they are glowing properly.
3. Hook up the two green twisted pairs and verify appropriate DC voltage coming out of the DC filament board (it will show 6.3V across the output terminals).
4. Hook up the high voltage winding last and do a complete voltage check.
PJ would have a more complete image in his head of how the high voltage winding might open up and short itself to one of the primary windings. I seem to remember that the low voltage 6.3V winding would be between these two, so another check you might want to do is to checK DC resistances between power transformer terminal 9 and the rest, as well as power transformer terminal 10 and the rest. 9 and 10 should show as almost a dead short and should be open to the rest, though in circuit you may see a few hundred ohms to 1K of resistance and that wouldn't be a problem.
In a situation like this it pays to be super careful when installing the new power transformer in case there was a problem in the amp that toasted the first one, as you could end up also toasting number two!
