I've been hoping to upgrade the stock pot in my SEX to a stepped attenuator, and have been struggling to understand the different types of attenuators, as well as decide which is appropriate for my purposes. To illustrate, I've found several dale-stuffed ebay attenuators, seemingly based on similar switches.
First, I believe this is a series type: http://www.ebay.com/itm/2P-23-Step-DALE-Attenuator-Volume-Pot-Stereo-100K-Y-/260857417997?pt=LH_DefaultDomain_0&hash=item3cbc50510d#ht_1481wt_905
This one has about the same number of resistors, but notes it is a shunt type: http://www.ebay.com/itm/4P-24-Step-DALE-Attenuator-Volume-Pot-Stereo-100K-Y-/250896216491?pt=LH_DefaultDomain_0&hash=item3a6a9471ab#ht_1443wt_1163
And this one is a ladder type, with twice as many resistors (though from a different seller): http://www.ebay.com/itm/Assembled-Dale-23-Step-Attenuator-Volume-Control-100k-/270311271326?pt=LH_DefaultDomain_0&hash=item3eefceab9e#ht_707wt_1163
Part of my confusion lies in the number of poles listed for the first two. Why does a series say two pole, while a shunt type is four pole? Perhaps I'm misunderstanding what a pole actually is, but from my research, each of these types only needs to have one switch for each channel, correct?
Secondly, it seems a given that the shunt and ladder types will offer higher sound quality than the series type. The shunt will have two resistors and one switch in the signal path, while the ladder will have two resistors and two switches. The downside to the shunt type is that it presents a varying input resistance to the source driving the amp. For a 100k attenuator, when would this be an issue? I run a Seduction into my SEX, and it seems that the input resistance will always be "ok", but is it likely to be enough of a concern to go with the ladder type, despite it adding an extra switch in the path and costing more due to the doubled resistors?
I'd really appreciate anyone confirming my theories here, and feel free to point and laugh, if it's appropriate.
Thanks very much in advance for helping me get my thoughts straight!
- Guy
- Guy
