mcandmar
I have a recurring issue in that tubes start making strange noises and eventually will get so noisy that i have to retire them. Each set of tubes seems to last me about a month, two at most. They get approx 8 hours of use every day so i estimate ~3-400 hours is when they start to give trouble.
What is happening now is one tube is making a faint bump, bump, bump sound. The interval can vary but its consistent in that the sound is always there, and it only started doing this since friday evening. I have switched the tubes around and the sound has moved channel so that confirms it is the tube and not the amplifier.
What is worrying me is this is the third set of tubes in a row that have failed like this, in fact some of the others were worse in that they would either make strange whistling sounds or randomly make a very loud POP sound which is never pleasant while wearing headphones. It has become so frequent now i am convinced something is wrong and killing tubes prematurely.
I ran though the resistance and voltage checks in the manual and nothing looks out of spec, if anything most of the voltages are slightly below the manual specs. The only one that reads in any way high was the C4S specs,
OA/OB read 72.4/77.5 (77 being the noisy tube)
10/20 read 413/413 (C4S manual lists 405v, whereas the main S.E.X. manual lists 420v ?)
I'm at a loss now, and slightly frustrated. I have another set of NOS tubes but i am loathed to install them until i have confirmed there is nothing causing this issue. Any thoughts, or anything else i should check?
Mark
Mark
