Yeah, that could present a problem down the road if the wrapping on the cap becomes damaged.zlib said:Oh, and now one of those capacitors' bodies touches one lug of heat sinks (where TIP50 transistors are installed). Is it bad?
The voltage at 9 dropping by 20V suggests that you have fixed a flaky solder joint.zlib said:7 - 108
9 - 98
Is it still cold joints or something else? In the past when I had problems with left channel the terminal 9 voltage was around 118.
zlib said:I rolled up the screws with cotton thread and now my meter shows nothing between the screw and middle leg of TIP-50 transistor. The voltages seem OK too, all LEDs are glowing (but the LEDs on small PC boards are glowing less than the others).
We use essential cookies to make this site work, and optional cookies to enhance your experience.
