Tube Socktes, Silver, Gold, Or Standard?
There was a Japanese company that was making molded composite, solid copper sockets a few years back but they were super expensive as well. More than the protos I had made, and the Yen rate hasn't gotten any better since then.
I found some tiny metal pipecleanerish brushes at a yard sale a few years back. I dip them in some contact cleaner and brush the sockets out every few months. Seems to have kept the crackles at bay. And living in Okinawa, life is a constant battle against corrosion.
I used the stockers in my Eros and if they are a weak link, the rest of the chain certainly makes up for them. The sockets are not easy to swap once constructed though. So if you have the bug, I would build it with the new ones.
Paul,
Thanks for the information.  Just to be clear to everyone, I was not complaining about the sockets Bottlehead supplies.  They are top notch current production sockets.  The same quality as any major manufacturer (ARC, Jolida, Manley, BAT, etc.) out there puts in their equipment.  (Ok, I was delusional.)  Using specific examples, the more current manufactured preamps I owned were an (made ~1996) and a Counterpoint (made ~1998).  Both used sockets similar to Doc's but those the mount in a PCB.  The sockets I got in a grab bag from Manley Labs at VSAC 2003 looked much cheaper than Doc's.
Any mechanical connection is unreliable.  This is one we tube aficionados have to put up with.
ssssly,
I'm looking for a reasonable alternative.  I have some silver plated PCB mount sockets I have used for 20 years in Dynaco rebuilds.  They have been extremely reliable.  I have zero confidence that the "sliver plated" sockets coming from China are even tin plated, much less silver.
That is why I was looking for a reasonable alternative.  That, to me, means under $10 per unit.  Thinking about it, copper oxidizes and the oxide is pretty bad.  If the copper is in contact with a tube pin the contact won't be compromised. But if it moves you have an ohmic contact.  Considering the high price I will no doubt pass.
I tried to say out of this discussion but Graingers last comment about the top notch current production sockets that Bottlehead uses in their kits is the same quality as other major manufacturers is just delusional.  I stopped using the kit sockets and rca's along time ago, Bottlehead sockets are price dependent not quality dependent which keeps the cost of their kits down, and these and most inexpensive sockets usually cause problems down the road.  Because this is DIY and tube rolling is a absolute addiction for me I have made the decision to eliminate possible problems by using a better IMHO product.  Rebuilding a project because of a bad socket or rca is a real pain, especially with the upgrade boards that cover up any access to the socket, and it usually destroys the original neatness of the original build.
I never use gold plated anything (one exception); after reading an NASA article about not using anything that is gold plated because of the poor quality solder connection created and of its greatly reduce reliabilty I stopped using most parts that are gold plated.  Yes, I do realize that none of my builds will make it into space, just being the annal retentive person I was born, can't help it.
Here is my short list of better sockets:
Yamamoto Teflon (Cu, Silver, Gold), extremely expensive but the best pins I have seen.
CMC, Connex or Valab Teflon and Bakelite, all gold plated, Yamamoto clone.  (my one exception to not using gold plating) I usually try to use the small round PCB especially with the 9 pins sockets which makes for an extremely neat installation.
Angela Instruments silver premium ceramic sockets, best ceramic socket I have seen, top and bottom chassis mount and PCB, use these alot.
QQQ Bakelite sockets made in Japan, best bang for the buck, chassis mount only, also used alot.
Belton, terrible beige color, chassis and PCB, also has a PCB version with extra long pins.
Blue Tefcom Teflon composite silver version, like the Belton do not like the color.  Same price range as the Angela premium but IMHO the Angela and QQQ are better sockets.
Again like Grainger I am not "complaining" about the Bottlehead tube sockets and rca connectors.  I have stated in the past that I believe that Bottlehead should have an limited "upgrade Kit" option with better sockets, rca's, etc.  I would rather give Dan and Eileen my money, but do understand that this upgrade kit would result in a larger more complicated inventory for them, spent 30 years dealing with an ever expanding complicated inventory.  I also would expect to have to pay more for these items through Bottlehead but in the long run it would save one money because of the lack of purchasing duplicate items and having sockets, rca, etc. sitting in a box on the shelf.
Lee, thanks for the great list of quality sockets. I'll get hold of some to play with for sure!
When the Yamamotos (and their imitators) first appeared, I recall seeing some complaints about teflon "flow", with sockets coming loose as the mounting screws relaxed, and the pins coming loose. These were of course forum reports, not my own direct experience, so I don't really know how true they were. Have you had enough experience to comment?
A quick look says a few of the sockets on your list claim phosphor bronze pins, which - at least at one time - was the preferred metal - flexible and strong. I can't find any claims at all for the others, and I've certainly run across more than a few cheap copies of traditional designs that seem to be made of pot metal or maybe melted down beer cans.  :^)
Lee,
None of those above, except the Belton and Angela, are "reasonable" by my definition above.  But, for such prices, they should be good.
PJ, do you have any experience/recommendations?  If you prefer to PM I will keep it under my hat.
In case you missed it I mentioned in an earlier post the Belton sockets sold by Partsconnexion.  They are the tightest sockets I've ever used.  I really don't see them getting loose anytime soon either.  And they're under $3 each to boot!
Here's what they say about them:
pcX is pleased to once again be stocking a variety of Belton Engineering tube sockets (made in Korea). Regarded by many to be the best molded plastic (Micalex - glass fiber filled PPS insulation material) sockets ever made, these parts have become very popular amongst Guitar amp manufacturers, as well as an increasing number of high-end audio tube electronics manufacturers, due to their super reliability.
NOTE: Sonic Frontiers was one of the first high-end audio companies to use these sockets, back in the mid-1990's.
Featuring solder-plated phosphor bronze contacts, the manufacturing quality of these sockets is superb, with extremely strong contact elasticity.
Eddie Current is making a 4 pin, teflon, silver contact socket that, while very $$$, is also a new design.
It has adjustable pressure so you can get a good fit with pins that are even slightly "out of round" which isn't unheard of.
IMHO, if you're planning to spend the big bucks on a socket, buy some that have a design advantage.
http://www.eddiecurrent.com/Tube_Socket.html
Rob,
Yes, Thanks!  I have bookmarked the Beltons as a reasonable possibility.
Steve,
No, I hadn't seen them but I'm looking for reasonable.  The design looks good.  It seems to be a "tulip" style which makes sense to me.  I'm not sure what he means by "adjustable."  Maybe the nut on the bottom of the socket adjusts height or tension?
Grainger, I don't have any recommendations. I have some stash of old sockets, and when those run out I just grab whatever Dan is putting in the kits, when he's not looking.  :^)
In principle, I would probably go with phosphor bronze as the metal when I can find it. The Wikipedia entry says it has low friction and freedom from metal fatigue, which should make repeated tube rolling more reliable. The phosphorous is said to remove oxides (the primary form of corrosion) and clean up grain boundaries. These are things that cable students think are important. Beryllium copper is stronger and a better conductor, but the toxicity of beryllium seems a downside to me. Both alloys are widely used for springs and electrical contacts.
My negative socket experiences have always been contacts that get deformed and lose the ability to make a good connection. This would be expected if the chosen metal is not free from fatigue or is weak.
