Not at all. The cathode follower has no voltage gain, so slight imbalances like that won't be audible like they might otherwise be with a standard voltage amplifier.
That's a bit of an overly general question. You'd have to ask the specific differences between two specific tube labels to ask a question that's more answerable.Jake1 said:-What does the info on what all the numbers/letters mean as far as compatibility goes?
Sometimes there isn't any beyond a different box and some different printing on the tube. Sometimes there is an extra mica support inside the tube, sometimes there are other modifications for better shock/vibration performance. This is dependent on the tube itself and what the datasheet might or might not call out.Jake1 said:-What is the difference between military vs nonmilitary tubes?
Nope.Jake1 said:-Does the speedball installation make a difference with tube compatibility?
Yes!Jake1 said:-Would accidentally using an incompatible tube cause damage to the amp or voltage discrepancies?
Jake1 said:What does the info on what all the numbers/letters mean as far as compatibility goes?
Jake1 said:Thanks for all the info! Also is the Mullard CV2984 6080 6AS7 tube compatible with the crack? And how do you check the compatibility between tubes and amps?
The CV2984, the 6080, and the 6AS7G are all different tubes. They all work in the Crack.Jake1 said:Also is the Mullard CV2984 6080 6AS7 tube compatible with the crack?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
