Tube Rolling w/Crack
guys..
what's the difference between a Tungsol 6080wb and a Bendix 6080wb
based on this listing, there' s a HUGE price difference.
http://vacuumtubes.net/RES%20Audio%20pages/6080.html
few months ago i bought a Tungsol 6080wb slotted graphite tube from a head-fi forum member and i thought i got a great deal. please see the attached three pictures. and to be frank, it sounded better than the stocker Sylvania 6080wb that came with the amp. the tube clearly has the markings on the bottom metal part of Tungsol 6080 on it. and it's graphite column with slotted hole in the middle.
but now i am seeing this huge price difference between the red lettering Bendix 6080wb on the glass slotted tube vs the TS 6080 slotted tube i got. did i buy the wrong tube? i thought all Tungsol 6080 are the same as Bendix 6080 they're just rebranded. but why the huge price difference.
and here is a picture of the supposed Red lettering Bendix 6080 graphite tube that's so expensive.
howzz1854 said:
guys..
Your Tungsol slotted graphite plate was made by Bendix and is essentially the same tube but the Bendix red bank printed tubes are just a bit more sought after because of the Bendix print branding .
From what I have been able to gather pretty much all the graphite column 6080 tubes (there are many variations of shape and size) irrespective of branding were manufactured by Bendix.
Many of the commonly sought after premium priced tubes can often be found with different branding or code designation for substantially less than the more commonly sought after but identical tube.
Don’t be caught out by The $35 6AS7G Mullard that is on the list as it is most probably a rebranded Svetlana 6H13 (Mullard didnt make a 6AS7G as far as I am aware) and while they sound ok they can be found for under $10 new on ebay with a world wide search. They have been turning up more and more with  premium  branding with some sellers asking $100 or more so watch out and be sure to do some homework on potential purchases.
thanks JamieMcC, THIS is so helpful. thank you so much!
i can't seem to find any reviews on this online retailer Vacuum Tube Superstore http://vacuumtubesuperstore.com/tung-sol.html
has anyone bought anything from them? is it trust worthy or no. good experience?
Guys... is this TS 5998 legit? it's got the domino plate and says 5998 on the glass. the price doesn't look outrageous.
http://www.ebay.com/itm/262613766755?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
but it says Gold Aero and not Tung Sol. some say that TS is the only manufacture for domino plate 5998.
any thoughts?
i am just wondering if this is the same famed TS 5998 and if i should get it.
I have a Heintz and Kaufman 5998 tube, and I read that the Tung Sol 5998 is overall the "best" tube for the Bottlehead Crack w/speedball.
Also, are the 5998 tubes from Heintz and Kaufman and Tung Sol essentially the same tube, or does the different manufacturers mean that there may be some sound differences?
I don't see much info on the Heintz and Kaufman 5998 tube (with a quick google search), so I would like to know what's the general consensus on them.
I may be ill-informed, but all of my research that I've done regarding the 5998 states the true "domino plate" 5998's were ALL manufactured by Tung-Sol, so anything else is just a re-branding.
Heintz & Kaufman were in South San Francisco in the 30's an 40s, specializing in making tubes with tantalum plates called Gammatrons. Some of you may have seen a 24-G Gammatron I posted on instagram a while back. Bill Eitel and Jack McCullough who formed another Bay Area tube manufacturer with the Eimac brand name, both worked there before starting their company.
https://www.instagram.com/p/BIX8Cb8BpBo/?taken-by=bottleheadaudio
Kaufman left H&K in 1946 to start Lewis and Kaufman, and H&K became known as a reseller.  So I would also guess that the Heintz & Kaufman 5998 is a rebrand.
This?
https://tubeworldexpress.com/collections/power-tubes/products/copy-of-best-5998-5998-tungsol-black-plates-1950s-rebranded-heintz-and-kaufman-nos-gm-8250-5000-and-8750-5000
Sure they are re-branded 5998.
Thanks for the information!
attmci said:
This?
That's the one I got. Might it be time for a new tube if one channel starts to make static-like noises? I have other tubes and can say that only my H&K 5998 tube has this problem.
How many H&K 5998 tubes do you have? All have issues?
I've used the search and google but can't find anyone using the ECC40's (= E80CC with rimlock base, needs adapter).
If used, how are your results with these tubes in Crack?
I don't believe anyone has installed a rimlock socket on a Crack, you should give it a shot!  Do be aware that the E80CC works better in the Crack circuit running a little less current than the 12AU7 to bring its plate voltage closer to spec.  These mods are outlined by those who have performed the modification.
Thank you for the reply. I stumbled upon these tubes when reviewing E80CC options because i liked those best with my crack.
The operating points aren't exactly the same but close enough to use them with the E80CC bias for crack.
Here in Europe they were fairly popular because they were build for low microphonics (compared to their predecessor; 6SN7) and linearity.
Nowadays the prices are very low because of the B8A (Rimlock) socket that is needed.
The reason i asked is because i've been using these for the last few months with most excellent results (especially the Hungarian) compared to other tubes i use in my Crack (12au7's, 6F8G, 6SN7, 6C8G, 6SL7, 6CG7/6FQ7, E80CC, 12BH7 and 5687/7119's).
Hello all, i'm currently using a Mullard 12AU7 cv4003 and a Mullard 6080 cv2984. I would like to get a Tung-Sol 5998  to pair with cv4003, but these are thought to find.
So i was wondering, what would be a good price for an used 5998 tube nowadays ?
Also what would be a good ma and gm rating for an used tube ?
I remember someone on head-fi said that the Crack tubes are Russian NOS tubes. But my Crack came with 2 made in USA tubes.
Don't get me wrong. I prefer made in USA or England tubes. Just curious why they are not Russian NOS tubes as someone said?
There are no Russian 6080 and 12AU7 tubes.  You can fit a 6H13C which is a Russian 6AS7G, but there is no equivalent to the 12AU7.
