So, I built my Crack +SB in 2014 and it's always in play with my Technics SL-1200 turntables. I recently started revisiting the Bottlehead forum after experiencing some noise (hum and buzz) and wanted to see if I could eliminate it. I ended up re-flowing all the connections and added the ground diodes. I also cleaned up some of the wire runs and shortened wires where I could.
What I discovered is that the I could achieve dead silent amplifier operation when a Chatham 6080WA and and various Tung-Sol 12AU7's were installed.
The same 6080 and one of my Channel Master 6SN7GTB's produced the same dead silence.
What gave me noise was a Chatham 2399 and various 6SN7GT's (hum and buzzing). Other than the Channel Master tubes (which are excellent!), all of the 6SN7GT's (VT-231's) experienced some humming no matter what I tried to fix.
I am guessing the noisy tubes I have are less than perfect. I have a couple of pair of RCA 6AS7G's that sound great but the glass (or other) vibrates into high pitched noise. It can be eliminated with much pressure on the tube but I know that dampeners can kill the audio. It's not so annoying for listening but is clearly audible in between tracks.
Back to the Channel Master 6SN7GTB, I was able to acquire 3 of these Mullard made (Japan) tubes for $20 per tube recently and they are outstanding. I'm not sure if they are better than the Tung-Sol 12AU7 but they are at least the equivalent. I need more time with them. I bought a 6SN7 adapter from Garage 1217 and it's very nice quality. I wanted to guard the exposed solder pads and came up with a simple plastic removable sleeve. It's actually made from just a $1 sink drain pipe from home depot. It fits perfectly and looks like it's part of the tube when placed over it. Anyway, this amplifier is just amazing in performance and simplicity (and superb electrical engineering!) It's so good I am wondering if a Crackatwoa is worth upgrading to. Or an S3X for my HE-6se and Grados (I use SS amps for them).
