fullheadofnothing said:The "check" to see if it is the tube or the amp would be to try a different tube. You have done that. From the obvious conclusions drawn from that test, the solution to this noise issue is a simple two step process.
Step one: Put in the 6080.
Step two: Listen and enjoy.
attmci said:1. Clean the pins.
2. Try another drive tube?
Hey, if you wait a bit longer into the video, you can see the power tube fluoresce.Caucasian Blackplate said:I see your 12AU7 doing a bit of a flash, not the 6080. This is often referred to as "The Mullard Flash" and isn't anything abnormal.
calmiswar said:Thanks for the reply PB and Doc!
The tube seems to be working perfectly. I'd highly recommend the GEC 6080.
Sorry, I don't think you can use ecc81/6060 tubes on a Crack. You need a 12au7/ecc82/7316/5814/cv4003/cv491/ecc802/b749.SxVa said:Hello. I'm new to tube rolling with the crack. For my first time to replace stock i went with a 7236 Tung-Sol for my power tube and i'm finding it pretty interesting, quite the change from the stock RCA that came with my unit, the instrumental parts are much more present to where i feel like i'm sitting right by the band but the vocals aren't as prominent and don't stand out as much as i typically enjoy and tends to be a focus on basic setups to emphasize vocals and so it was somewhat of a drastic change for me but it's interesting.... and now i want to get a new input tube, firstly i went with a NOS Tesla which hasn't shipped yet, and now i have my eyes on a Brimar yellow T.
I found a 6060 yellow T from the early 60s on tubeampdoctor which i could go with.
There's also cv4024 and a 6059 yellow T on valvetubes with little info provided and i could get both of them for the price of the 6060.
And i just found another one on bestsfad.top which has 4 of the 6060 at only 43.99.
How do i know what's a good buy and what isn't? There isn't really a lot of info or high quality pictures in a lot of these various listings.
Are any of these good options or should i keep looking elsewhere?
Also, another question. I'm more interested in medium range priced tubes than the best as i find i'm the most comfortable in this range in most things and was wondering if there was any up to date list of reputable vendors for this tube/valve range that exists? Is simply going by Ebay ratings a good enough indication of getting legit valves/tubes? It's very overwhelming coming into this whole thing with so many different things to look for and not knowing what's a sure thing. So far i like thetubeking on Ebay because they show dates and where the tubes come from and don't shy away from the fact the tubes might not be the best unlike a lot of the others on Ebay which hypes up every tube. That's where i got the Tesla but it's difficult to know what's legit or not.
attmci said:Sorry, I don't think you can use ecc81/6060 tubes on a Crack. You need a 12au7/ecc82/7316/5814/cv4003/cv491/ecc802/b749.
A 12AT7 and a 12AU7 are very different tubes.SxVa said:Oh really? Well dang. I had my heart set on the yellow T.
Thanks for the response. At least i found that out before i bought it as i was close to buying it. I figured it was an "equivalent to" as there seems to be so many equivalents and i read a description of it under an 12AT7 tube guide. I guess i should just stick to those specific tubes listed then to be sure.
A 12AX7 (ECC83) and a 12AU7 are very different tubes.SxVa said:Oh and one other thing. So ECC83 definitely doesn't work? Only ECC82? I've come across a lot of ecc83 and so it would be good to know for sure.
Caucasian Blackplate said:There are adjustments to be made for the 12BH7 to bias properly in the Crack.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
