L
Loon
Guest
How do I work out if a particular wire is in the signal path?
For instance, is the wire between terminals A1 & 5L in the path of the signal?
Could I permanently insert an ammeter in series here without affecting the signal?
Could I permanently place a voltmeter in the circuit to measure one of the anode voltages of one of the triodes of the 12AU7 tube in a manner that would not affect the signal. Could you please explain to someone of the meanest intelligence (me) how to achieve this in theoretical and practical terms?
The reason for my question is this:
Based on the circuit diagram I assume that the anode voltage of the 12AU7 sets the grid voltage of the 6080. This is ideally 75V.
I will be inserting a switch into the circuit that will allow me change the plate load of the input tube, setting good operating points for a 6SN7GT and an ECC32. These operating points *should* result in an anode voltage of 75V.
I want a foolproof way of making sure that the I have the plate load switch in the correct position for the input tube I have inserted at the time. A voltmeter showing the voltage across one of the anodes in the input tube should achieve this.
I only want to implement this if I can be sure it will not effect the signal.
I know nothing about electronics, though. Please simply let me know if it would work, the reason why it would/would not work and, in practical terms, how I would implement it.
Thank you very much for your help.
