hello all
I'm interested in the new amp and have couple questions ... and sorry i don't know much about this stuff !, I have a crack amp with hd600 connected to my high end PC with a creative ZxR soundcard and really like it
and was think of rebuilding it soon but may change my mind
Does having the exrta 2 tubes 6AQ5 affect the tube rolling on the new crack? .. will it be the same any different, I liked the way the 5998 changed the sound and wish to use these.
with changing the tubes on the normal crack really changed the sound for me, / i was thinking with these other new tubes the crack tube rolling may be different , sorry I don't know alot with this stuff guys.
Also can you change the 6AQ5 for different types and makes? , will this change the sound as well?
one of the biggest things I'm concerned about is interference noise pickup from computers and stuff? does the extra tubes effect the amp near computers ? My crack about 1 foot away from my computer but its dead silent, I can turn the amp up near full wack with no music and only then only hear a little noise (the last 1 cm of volume travel and thats blown up headphones loud and no hearing! shes perfect ....shes quiet as a mouse with good tubes)
so I'm worried about this with new amps near my pc I read valve amps can pick up noise , more chance of this happening with new amp design? :-*
also does the new amp have loads power like the normal crack
is the bass any different. I'd plug in a 5998 and work ok
I listen to my music loud and hope it has lotsof big power and can go loud
Guys does the mainline amp have bigger bass fatter bass with hd600 than the old crack speedball and 5998 tube // using high impedance headphones ?
When I installed the 5998 on my crack speedball I got a bigger sound better bass and it was less harsh with my hd600s smother sound darker sound I think you call it..
sounds awesome with my italo disco 8) 8) it thumps
Im not really interested in analyzing my music I like a rhythmic musical tubey sound, warm detailed
How does the new amps volume control and balance work ...... is it like a normal amplifiers left and right balance .... does the upgrade change this? / course and fine I dont understand it anyone have a link to explain how it works ? i will look up later but its late tonight sleep soon
I've read a little about stepped attenuator but still dont understand it ..... difference with a shunt course fine , I may build my own stepped attenuator one day for my crack but have to learn it carbon film resistors and things
I have no problems with my cracks channel balance though still use the standard pot
I was even thinking of buying one but with the money I could be put towards this new amp plus I always wished i painted my top plate and was think of adding a choke soon never got round to that, and fancy building an amp again as I enjoyed building the crack
finally does the upgrade part the stepped attenuator come with a black top plate like the mainline? with writing dials,
if so will it look like the mainline design or like beequiet and others , the mainlines top plate looks nice
