ALL212
I've been thinking about doing this for some time and finally got the plate cut and all the parts in. This is a Crack/speedball on a 10" x 12" plate. Lots of room to throw some big stuff around.
Changes:
Replaced the last power supply resistor with a choke.
Cap #1 and #2 are JJ caps. The first tipped with a 4.5uf Solen, the second tipped with a 1.0uf Clarity cap. Values were not "chosen" but I happened to have these laying around.
Cap #3 is a 220uf Solen.
upgraded the RCA's.
GoldPoint 24 step attenuator.
Replaced the 9 pin socket with an 8 and wired it for 6SN7 use.
Moved the power switch to the front.
upgraded wiring - Teflon coated silver plated stranded copper for most of the signal path. Mogami W2534 between the RCA's and volume.
Plate painted - I used black hammered rattle can but heated the plate. It made a nice matte finish.
Parts installed. I made a mistake on my drawing in that when I replaced the 9 pin socket I centered the 8 pin. That moved the screw hole just a bit closer. Large speedball board still mounts but not with both screws.
Towards the end of the base build I broke the lead off of one of the big clarity caps. It had been repurposed from a prior build and the lead had been bent too many times. I installed the stock caps and it tested good. I then realized that if I had installed the large caps I would have had a very difficult time installing the speedball. So while waiting for the new caps to arrive I've installed the speedball.
Build sequence.
Original plate Crack next to the larger plated Crack. It is much easier to put the big stuff in under this larger chassis.
Changes:
upgraded the RCA's.
Build sequence.
