Taking orders :)
I have 10 days left to return my Emotiva Dac, but it could still be a long wait for Docs Dac! I don't think I can go back to my Fiio E07 while waiting.
Well you definately need something to listen to while you are waiting. I've been waiting a couple of years now. Doc B won't release anything until its just right, as it should be. I hate it when companies release a product when it isnt exactly "ready for prime time." Bottlehead hasnt let me down yet.
A friend of mine loaned me his Emotiva Dac when he bought his Schiit Bitfrost. I wasn't overly impressed with the Emotiva. Don't get me wrong it had some good qualities but it didn't have much to offer over and above an old VA Labs DAC I was using at the time. I wound up with the MyDAC as my interim DAC while waiting for the bottlehead DAC to be released. Some people dont like the plastic case on the MyDAC but it doesn't matter to me. Its what's inside that counts and it sounds real good in my system.
Honestly, I hate to be the one to ask this as the answer surely relies on many decisions yet to be made but... Ballpark cost tier? Is this DAC catered to a Crack, S.E.X. or Mainline consumer?
EDIT: Sifted through the post and managed to find the answer I was looking for.
For those stumbling on this post recently without going through it thoroughly:
Doc B. said:
Due to the level of circuit sophistication the pre stuffed boards for this DAC are complex and quite expensive. I'm wrestling a bit with the pricing now that we have the project fairly well developed and I think the price will be under $1000. Probably not much under but we're squeezing it as hard as we can, short of hurting the sound.
The price is still a moving target, partly because we are still refining the battery supply size and charging circuit components. But it is definitely more of a trying to keep it under $1000 endeavor than a $250 kit. The DAC board itself is very expensive to have manufactured.
Understood. Thank you for the prompt reply Doc.
I want people to remember that this is not a "cheap DAC", this is the best I know how to make right now. There is no skimping on anything to a price point. Fortunately I know how to get exceptionally good sound without having to spend thousands of dollars on a single part!
For example this DAC has 6 ultra low noise regulators, they are not cheap (about $7 a piece), but far less than other "top of the line" DACs that use $75 regulators that don't perform any better.  Or less expensive DACs that will use 2 $1.20 ones. It gives performance way better than the cheaper ones without the exorbitant prices of the other "statement" DACs.
Oh and Doc, I have a new filter that is significantly better than what you have now. I threw the one in your DAC together in an hour to have something you could hear. A couple weeks ago I spent some time with a friend and we tweaked the filter parameters to significantly improve the sound. By the time we were done it was the best he had ever heard. (and he has a special custom DAC that WAS state of the art)
I already have a pretty good CD/SACD player, a Marantz SA-11S3.  I'm thinking of running the analog outputs into the BeePre (just as I'm doing now), the digital output into the BH DAC and the output of that into a second input of the BeePre.  The point of this is to improve standard CD playback.  Questions:
1.  Is there any reason why this wouldn't work?
2.  Is it a correct assumption that the BH DAC will most likely sound better than the built-in DAC of the player?  John has already indicated that the SPDIF input will sound equally as good as the USB input.
Thanks.
Gerry
        Is it time for a Forum Pool?
        Person closest to the actual price and open for orders date wins a Bottlehead Badge for only $6.00  +(S&H)  :)
Hello everyone:
My first post here.  My name is Alex Crespi, and I am the friend that John Swenson spoke of above.  John and I have known each other for about 9 years.  I first contacted him for an ahead-of-its-time digital project back in 2005--when Hovland Company, of which I was a co-founder, was still in operation.  In fact the DAC which the Bottlehead prototype went up against on Janaury 4th is one of the NOS PCM1704K prototypes with discrete output stage that I inherited when Hovland closed its doors.  It has had work done to it since: John put in a WaveIO async-USB>I2S board and better power supplies for the digital side.  (If you want to know more about me or my system, I use the same Superdad handle over at ComputerAudiophile.com)
My custom room and system are pretty advanced, and I upsample Redbook to 176.4KHz with Audirvana Plus on a fine-tuned Mac mini booting a very slim OS off an SD card.  I have spent a lot of time tweaking all the filter parameters of the iZotope SRC engine that A+ uses, so I have a good ear for what the parameters do.  John's visit to my place this month (I'm about a 3 hour drive each way) was not his first, and we have spent time tuning a filter for a PCM5142 (the chip in the forthcoming BH DAC) before.  It is amazing what a custom digital filter can do for an otherwise ordinary sounding DAC chip.  The filters in most all other DACs are terribly compromised--especially if they are only the ones within the chip as the resources are terribly constrained.  But the FPGA designed into this unit you have all been waiting for has plenty of room to load and run a really good filter.
At first we listened to the BH DAC fed by my Mac mini (both with iZotope upsampling and with that off to listen to the filter John already had in the BH FPGA).  Power was provided by a prototype of a new PS that John and I will be producing in the next few months.  The BH sounded pretty good.
John has techniques to output a list of filter coefficients from the excellent SoX sample rater converter--and to then load those into the FPGA.  So what we did then was run SlimServer and SqueezePlayer on a Wandboard under COS (a customized Linux that the folks involved in the Community Squeeze Project have created--John is chief hardware designer for that non-profit project), and used the SoX plug-in to upsample to 352.8/384KHz (that rate turns off the PCM5142's own filter, and John turned off his FPGA filter).  The filter already in the FPGA was based on some of the intermediate SoX parameters, but was not critically tuned to this DAC.  The parameters are: cut-off, pre-ring/post-ring balance (that's the range of minimum-phase to linear-phase), filter length (that's number of virtual "taps"), steepness (for SoX this is controlled by frequency of cut-off and final cut, if I recall correctly).
Anyway, once we deciphered the numbers and ranges to enter the parameters (on an ugly command line for the SoX plug-in), we were able to spend about 90 minutes with the same four VERY revealing tracks (real instruments, real spaces, very challenging material top to bottom).  We went one parameter at a time, bracketing wide, then narrow, until we were making the smallest possible adjustments.  It is an iterative process (meaning we sometimes came back to one parameter after tuning another) and somewhat tedious, but John's ears, my system, and my 40 years as an audiophile/music lover (I started when I was 12) made it pretty easy.
In the end we were both grinning like fools.  Really that DAC chip (and its built-in opamp output stage) had no right to sound as good as it did.  Cymbals, piano, voices, strings, bass, drums--all top of the mark.  I have heard a lot of DACs, and I am convinced this Bottlehead DAC will go toe-to-toe with some mega-buck units!  Of course John quickly wrote down the numbers for the magic parameters we had settled upon and he's converting them for loading onto the FPGA.
So Doc, I think you'd best mark me down for a Bottlehead DAC too!  (I don't mind coming after everyone else here who have waited so patiently.)
Anyway, I just though you might all enjoy a little insight into the final stage of what is going to be a GREAT and very musical DAC.  It would be a steal even at twice the price of whatever Doc ends up asking for it.  Based on what I heard with my own ears, I don't think ANYBODY will be disappointed.
Best regards,
ALEX
Yeah. Word. Really amazing to get these insights into how much time, effort, patience, and dedication to quality has been put forth on this product development.  Pretty cool stuff.
Hi Alex,
Thanks so much for this added information and impressions.
One thing that has not been mentioned so far is how this dac does on tone -- in other words, where does it sit on the tone color scale. More to the Linn side or more to the audio note side?
Jim
