Umustbekidn
Hi folks,
The crack has been used daily since we got it running a few days ago, and I'd swapped out numerous 12AU7 tubes - so I know the current tube had been working (all with the same power tube). Today I received a tung sol 5998 from ebay and proceeded to swap power tubes...
When I powered up with this new(old) 5998 tube, I saw a much brighter than normal glow from the 12AU7 tube, then saw what seemed to be a flash from the 5998 power tube. I also heard a faint pop from somewhere in the amp.
Thinking the 12AU7 had blown, I replaced it with a known good tube. It did not glow normally at power on, and the new 5998 was glowing very brightly - and not producing sound.
I unplugged everything and ran resistance checks, results below. A few things have changed. I also smell something faintly like burned plastic. No visible damage I can detect.
It is unclear if the new tube was bad and blew the circuit, but it was the only thing I'd changed prior to this event. Can someone help determine what went bad, so I can replace things? Can a bad tube do this, or could this just be bad luck? Wondering if I should return to the seller as damaged.
Terminal = Reading
1 = 11k and rising (was No Reading at assembly)
2 = Less than 0?! (was No Reading at assembly)
3 = 0 ohms
4 = Less than 0?! (was No Reading at assembly)
5 = 20k and rising (was No Reading at assembly)
6 = 0 ohms
7 = 3k ohms
8 = 0 ohms
9 = 3.4k ohms (was 2.9k at assembly)
10 = 0 ohms
12 = 0 ohms
13 = 2k ohms and increasing
14 = 0 ohms
20 = 0 ohms
22 = 0 ohms
B3 = 3.4k ohms (was 2.9k at assembly)
B6 = 3.4k ohms (was 2.9k at assembly)
RCA centers = 100k+ ohms
RCA grounds = 0 ohms
Thank you kindly for your help.
Terminal = Reading
3 = 0 ohms
6 = 0 ohms
7 = 3k ohms
8 = 0 ohms
10 = 0 ohms
12 = 0 ohms
14 = 0 ohms
20 = 0 ohms
22 = 0 ohms
